Nibor
Bewildered
- Accrington
HI Accy I'd call Autofix in Accrington for a quote always very fair with me and I would't use anyone else mate.
The garage I go to for my MOT seem to be able to check on fitting times and prices on their computer.
If it is anything like my old Corsa B it could involve removing things like the air filter box and supporting the engine to remove an engine mount in order to remove the belts .
Yep, on a scale of 1 -10, probably between 0 and 2. And even if you can get the leverage to turn the bolts or nuts, the chances are some stripping of the threads will happen.Quick question. I need a new back box on my car - it's only been on 18 years. I know the exact part I need (two possible options on my car but mine is the early one). Easy access, no complicated routing. Chances of me undoing the two bolts with impact sockets and a breaker bar - probably zero !
You are likely to need new clamps anyway, so at the first sign of resistance I'd go for an impact driver. If that failed to persuaded the metal, then I'd be reaching for the grinder.
Or the ICME if they're really posh.Yep called Autodata
Don't do Posh, it's for err, Posh to do thatOr the ICME if they're really posh.
Funny enough did same thing on mine a week or two ago,a plumbers blow torch helped me out !Quick question. I need a new back box on my car - it's only been on 18 years. I know the exact part I need (two possible options on my car but mine is the early one). Easy access, no complicated routing. Chances of me undoing the two bolts with impact sockets and a breaker bar - probably zero !
Sierra
