Things You've Learnt From Fettling
gbb
Peterborough
Always open up a hub over a laid out cloth or rag.
Many 'cartridge' bearings (I hate that term, they are just bearings) can be serviced or have their life extended by flipping the seal, applying grease then re sealing.
Bearings can be replaced in outboard cups, done campags and FSAs.
Check you tightened everything when done.
Moodyman
Jobs you put off or are told are difficult are usually a lot easier than expected. Stuff that is supposed to be straightforward...well that seldom goes to plan.
If you are dismantling something, take loads of photos as you proceed.
I've never done that however what I do is place the items on a tray in the order they came apart.
I do both of these with anything mechanical, not just bikes.
Also, make a habit of smearing grease on all bolts before replacing. Makes life so much easier down the line.
