rogerzilla
Oh look, they've reinvented the Brompton 6-speed (and many SA or SRAM-based hybrid gear systems before that).
It will be far too heavy. Hybrid systems are. A mere 3 speed hub gear weighs 1/4lb more than a 1 x 11 system, and about the same as a 2 x 11 system. Combine the two, and you're into boat anchor territory.
Hub gears are heavy because the parts have to be made from hardened steel due to the nature of meshing gears. There is no way around that, unless someone comes up with ceramic gears that work.
