Ladies saddle soreness
Paul_Smith SRCC
www.plsmith.co.uk
Surrey UK
I would go back to the bike fitter and explain that you still have an issue. There is often no magic wand with instant noticeable improvement, sometimes you simply need to use the data and feedback you have then experiment to find the best solution; especially with saddles and especially when it comes to soft tissue issues. Often this can not be concluded in one session, so yes get back in touch with them, a good fitter will offer more assistance until the issue is resolved as much as it can be.
In fairness to the bike fitter there is only so much analysis we can actually offer a lady, sit bone width and looking at your posture on the bike or the two factors that most will focus on; a 'sit up and beg' bike will normally require a different saddle to a 'long and low time trial machine' for example. We can normally recommend a saddle that matches the correct width to the correct posture, but that is where our analysis normally comes to an end; soft tissue can be a very sensitive area and indeed a sensitive subject, there are only so many questions that arguably for a bike fitter it is appropriate to ask and analyse, I have over thirty years experience in the cycle trade, bike fitting included; but I'm no doctor or gynaecologist. That is not to say with the information we have that we can't help with your choice of saddle and help you find the most appropriate one possible.
Saddles are occasionally bought on recommendation of another rider, but, it can be difficult, even folly for one rider to recommend a saddle to another, one may swear by a saddle where another may justifiably swear because of it! Saddle manufacturers are often well aware of the limitations of matching a saddle to the rider's personal data, as such most bike fit stores provide a service whereby you can try a saddle, they may have a variety of test saddles or a brand like Bontrager offer a comfort guarantee for example. I would imagine that the store who fitted you will offer a service along these lines enabling you to try some to find what you find personally works the best for you.
One thing you have mentioned is slanting the saddle helps (assume nose down), yet you feel the need to adjust your position pushing yourself back "up every minute"; this may not only be that the saddle angle is to acute. As rule of thumb on a road bike with relatively steep seat tube you would expect a lay back seat pin and saddle set back on the rails, positioning the saddle and rider as far behind the bottom bracket as possible, seldom will this equate being too far behind the 'bb', it is if anything often not quite far enough! Generically if your saddle set back is correct your 'core' is engaged, if the saddle is very slightly lower at the nose (emphasising only slightly lower) you should not feel like you are slipping off the front of it, as your core is in effect supporting you and all you are doing is reaching for the bars, not using them to prop you up.
If the saddle is set to far forward you may find your core is not engaged in the same way, so it will not be supporting you as lean forward reaching for the bars as well as if the saddle was positioned further back. Plus, although the distance to the bars is reduced, it can in some respects actually feel longer in as much as you may make the same compensations as if it was actually longer. This is because when your core is not engaged and your posture is as a result wrong you are having to use your arms to support you far more and you may feel more tension through your lower back, neck, shoulders and arms as a result. When set to far forward this also changes your posture on the saddle and that contribute to saddle discomfort; you may feel like you are often having to push back "up every minute." as you have mentioned; intuitively you may pushing back to engage your core without even realising that is what you are doing.
Much of bike fitting is spotting 'tells' like that, in effect the rider is showing to an extent where they need to be in part by the compensations they are making for the wrong set up. In my example above if the saddle is set to far forward and your core is not engaged, you may keep fidgeting on the saddle pushing back to intuitively engage your core, it may be less to do with the saddle pointing down, it can be more to do with how far forward the saddle is and how that effects how well your core is supporting you; or not. Note for all I know you are indeed perfect in that respect and it's purely a saddle issue!
On the subject of saddles, you have one with a cut out but the size and positioning can vary between models and manufacturers, some saddles are flatter than others and overall shapes and padding also vary and the comfort achieved as a result; so potentially try a different brand. In conclusion yes do flag the issue to the bike fitter; it may well be something as simple as a more appropriate saddle.
areyouactuallymoving
Stroud
Could it be the shorts not the saddle? I was getting a lot of pain and numbness even on relatively short rides <20 miles. Then I went for a ride without padded shorts and, while there was a bit of soreness on the sit bones, the soft tissue area was pain free. Granted an injury and lack of fitness means I haven't done any long rides without padded shorts, but could be worth a try?
postman
Meanwoodshire.
While i was away in darkest Lancashire.There was an article on Granada news about a female cyclist with the same problem.She needed surgery to sort out her problem.
Team GB cyclist Hannah Dines reveals she needed vulva surgery after years of saddle trauma
Hannah Dines had to have surgery after suffering swelling from five years of harsh impact of her bicycle saddle.
Tuesday 26 March 2019 21:07, UK
Image:Hannah Dines had surgery after suffering trauma to her vulva
Why you can trust Sky News
A female cyclist is calling for more research into women-friendly saddles after undergoing surgery for long-term trauma on her vulva.
Hannah Dines, a paralympian who competed at the 2016 Games, suffered with swelling on her vulva for five years before she was able to seek medical help, eventually leading her to get surgery from a cancer specialist.
Writing in The Guardian, she explained she had not received much guidance for dealing with the chafing and rubbing which riding a bike at her level came with, and between 2014 to 2018 the swelling grew to what she called "the dire end of the spectrum".
Image:WT2 Rider Hannah Dines with GB colleague WC4 Rider Elizabeth Saul
Ms Dines explained the vulva has a protective mechanism for dealing with continual impact, with a pocket of fat growing between the area which needs protection and the area suffering damage.
This cushion, a lipoma, was removed after two operations earlier this year, and Ms Dines said two tests for cancerous cells came back negative.
Advertisement
Pointing out the pain women already suffer with periods, sex and labour, Ms Dines continued: "I would accept this if, in comparison to every other aspect of the bike, the male-anatomy-specific-saddle hadn't received such a lack of research and design development as to be laughable."
Male cyclists also suffer saddle sores, but as Ms Dines points out "the valuable parts of the male genitalia can be moved out of the way, female cyclists sit right on the money".
CXRAndy
Lincs
Thats why nose-less saddles could possibly help, alleviating pressure on the central fleshy parts of both female and male genitals
Mrs M
Aberdeenshire
I was suffering with a sore “do da” :eek: :blush:
Found the Brooks saddle on the upright style Pashley ok but a bit uncomfortable on longer rides, no problems since wearing padded undershorts though. :thumbsup:
The very narrow Specialized BG saddle on the road bike is comfy, much better than the wider, more padded one I initially tried.
Had my seat bones measured at Edinburgh Bikes (just sit on a cushion thing) which measures seat bone width, then they can recommend saddles to try.
Hope you find the right one :smile:
Doobiesis
Doobiesis
Poole Dorset
Thank you for your detailed response. I found it very interesting to read. The saddle was recently fitted correctly with my bike fitting the only thing I have moved is pointing the front down a bit.
I have emailed the fitter but have yet to receive a response from them. Maybe it’s a case of still getting used to the way my bike is now. I am due to replace the saddle soon, so may well go to my local bike shop (Primera) to see if they can help me.
furball
As @Heltor Chasca said get in touch with dilglove and try one of the female selle smp saddles on a trial period and see how you get on
contact details on link https://www.dillglove.co.uk/contact-us/
+1
Just going to a bike shop will just give you more of the same advice. What you don't want is to be sold another saddle with no guarantee it will solve your problem. You are more likely to get a better result by consulting someone who is fully familiar with female specific issues.
Globalti
There's been a thread going on this in the health and fitness section for ages.
Doobiesis
Doobiesis
Poole Dorset
Ring up and speak to Debbie at Dillglove. This is a great company to work with for Selle SMP saddles. She is very customer focused and does the awkward ‘soft tissue’ conversation without as much of a blush. She is a consummate professional. She is like a family doctor, but for your bicycle sitting bits.
Have emailed them, thanks.
Doobiesis
Doobiesis
Poole Dorset
I went out today and noticed a pattern. I cycle fine for twenty mins but then find due to pushing back on the saddle, my shorts go up ‘there’. So I stop and readjust them. Ride fine for twenty mins and have to stop and repeat. It affects my speed and ruins my cycling. So I get back in a bit of a grump.
I emailed the fitter Monday but still have not heard back.
Reynard
Migrating shorts... Oh yes, am familiar with that one... :blush:
Would suggest going down a size and / or switching to capris. ;) FWIW, I did both.
Doobiesis
Doobiesis
Poole Dorset
A bike should be comfortable to ride from the off, you should not have to get used to it over time.
This is what I’m fed up with. Being in pain most of the ride, luckily I’m intent on cycling as, if I didn’t have it running through my blood, I would stop doing it. I still cannot do over 30 miles and it’s hindering my ability to build my rides up and get faster.
The company someone suggested, Dill glove, are calling me on Monday so am hoping they can help me. I’ve done loads with the saddle during a ride to make it bearable, I’ve tilted it and then levelled it, pulled it nearer the handlebars, put it farther away. Nothing works.am about to try the foil trick to measure my sit bones.
