MacB
- Farnborough, Hampshire
Ok, my package arrived from On One yesterday containing:-
Pompetamine frame XL in white
Pompetamine forks disc only white
On One forged alloy seatclamp
Planet X road strada 31.8 shallow drop 44cm bars
OnOne smoothie light headset
FSA OS120 road stem 110mm
2 x Avid BB7 road mechanical disc brakes with 160mm rotors
I dropped the frame, forks and headset in to LBS for headset fitting and collected them at lunchtime today. First problem, they had sent the canti, rather than the disc, forks. I hadn't looked and LBS have fitted headset and star nut, though the steerer remains uncut. Stupid of me but bloody annoying from OnOne as well, double checked my order and was definitely for the Pompetamine CroMo fork which the site clearly states is disc only. Message sent to OnOne and will get this sorted next week.
Anyway, on with the build, BB and chainset fitted no problem, disc rotor fitted to I-9 wheel and fitted caliper loosely to Pomp frame. Next I fitted the rear mudguard, SKS black, all went fine except for the fact that there's no drilling for top of guard bracket. There's a threaded hole underneath instead, so had to use screwdriver to make hole in top of mudguard and fitted via as flat headed a bolt as I could find. Fitted rear rack no problem, though legs share the same bolt as the mudguard stays.
Wheel fitting, it's currently shod with an M+ 700x35(erto 622-37) and this is as big as I'd want to go with mudguards. I have concerns about wheel removal and may change the tyres to a 32mm, due to the track end dropouts. Also not sure if I need some sort of chain tug, will discuss with LBS. The I-9 all slotted in just fine and no problems with the cable routing for the shifter. Also fitted saddle and seatpost, though saddle is temporary until I get a new one.
Parts still to come:-
aero brake levers and crosstops - I had wanted the Tektro RL340 in black but they seem to be out of stock everywhere, so now considering a Crane Creek option, but they are more than double the price. Also need to get the Tektro crosstops as they have the barrel adjuster as well.
brake cables, bar tape etc - these will be organised by LBS and I'll also finalise the BB7 setup at that point
front wheel - I don't have a disc front wheel and have decided it should be a dynamo one, just which one. I can get an Alfine centre lock one for £109 as a complete wheel but will then need to get a centre lock rotor or an adaptor. Then there's the SON28 available as a complete wheel for £208 from Spa Cycles. By my reckoning the cost difference will be about £60...decisions....decisions. Then, of course, there's the dynamo lighting but that'll have to wait until next month, but I plan on front and rear for this bike.
